21 - 40 of 42 Posts
Great thread, I think I will have to give this a try.
Funny enough like someone mentioned earlier this only started to happen when I began completely filling the Fuel tank every couple of weeks. The TT is used as a daily commuter now.
I also noticed the sound of the needle hitting the inside of the dashpod :?
You can see the problem with my Fuel Gauge needle below:
viewtopic.php?f=2&t=315291
Well dpbayly
Thank you very much. I had the same problem of over reading half a tank and the needle hitting the side of the gauge
I read the posts several times gathered some courage and tried this.
As the man says it works! Just take your time and de assemble the clock fascia completely ie take the glass out and you are good to go. I used a pair of pliers to remove about 5mm of trim, and then sanded it down, after a few trial fits and adjusting got it to the right shape to allow the needle free movement.
A week later and still ok.
Top man. :D :lol:
I had a go at doing this today, however I was unable to remove the needle? Even with a decent bit of force it wouldn't come off?
I could pull it and turn it and it would adjust the reading to full but turning the ignition off and on several times you could very slowly see it going further round.
I gave up in the end and put it back together without taking a bit out of the cylinder which was a big mistake as after 2-3 turns of the ignition it went way out again, so I should of still done that step as it may of taken a lot longer to go back out.
Will have another go at it on Friday, but any advice on removing that needle would be appreciated.
Martyn.
Martyn.
Same here my needle won't come off at all, even tried gentle force under it with a screwdriver but it didn't move. Must of been glued on in its past.
I did start moving the needle though gently between full and empty to see if returns to same position on its own (fully unplugged out of the car). At first it slowly fell back to the same start empty position then it stopped returning all together and I thought I'd broken it so I plugged the cables back in, turned on ignition and it instantly went back to how it was when I started.
I then unplugged the cables again and this time moved the needle too far left, way past empty (same position of the final settled point on youtube clip). When I did this the needle made a horrible click sound and assumed I def now broken it but to my surprise when I plugged it back in not only did the needle now go to the correct position, it now seems exactly the correct position and calibrated like new.
Have only just done this so will update in few weeks on how it turned out.
Ok the temp fix of manually moving the fuel needle didn't last, 2 days later and its back to its old self (ie full is way past F mark and empty is just under half a tank)
Got me thinking... As my needle doesn't slin independently of its axis but rather is glued on to the shaft of the motor, then there must be a way to reset / tweak, calibrate this with a laptop plugged in to the car computer. Can anyone point me to a thread or user that has dabbled with calibrating instruments via laptop? Cheers guys.
I've just done this procedure on mine following OPs advice, seems to be working at the minute, will update as time goes on - have to say however, there was much 'how the bloody hell did he do this in a petrol station' or words to that effect, but in all took me about 1hr, mostly getting the bottom dash section to fit back in place!
Nice one OP!
Hi guys
Excuse me for reviving the old thread)
I'm having a problem with my fuel gauge it stops just under the half full mark and doesn't move at all and the fuel low warning doesn't come one as I found out yesterday when I run out of fuel on a406 in London.
What can the problem be please?
As I understood if I'm not mistaken it's one of the sensors for fuel level.
Thanks in advance for your help
Check your range indication corresponds to the fuel in the tank when full and it goes down. That way you can see if the needle departs from reality or if both range and needle agree then you know it's the sensor.
Checked from full tank the needle and the range is moving back down and it looks they communicate right so it looks like the problem in sensors.
Do you guys know which one is it for the bottom half as mine sticks just under the half of tank?
Have a read of the Mk1 knowledgebase for access. There are two sensors - one for each half of the split tank. They are wired in series so add together so that the mean level is detected regardless of how much fuel share is in each tank half.
In your case it could be that one float is stuck or the wiper is not making contact - so that one reads full all the time stopping the needle dropping below half way whilst the other float effectively gives its reading in the top half of the gauge. Either float could do this.
You also have the complication that some cars were fitted with sensors that go high to low resistance as the fuel level drops and some cars have the resistance go the other way. The way to tell for sure is to pull the connector off and see if the gauge goes to full or empty.
You can try cleaning up the tracks with IPA or switch cleaner. At the same time you can check that the floats move freely. You can also measure the resistance of each sensor to determine which is at fault.
I know this is an old, old thread but ....
... tried this yesterday and so far so good. Thanks to the original poster.
A few things I would say -
- there must be a knack to wiggling the dash out, I made a proper mess of it and scratched up the top face plastic of the steering column. I'd recommend covering with masking tape before you start
- the needle is a pain to remove. I used a lightly modified dessert fork to lever it off
- make sure you wipe finger marks of the reverse side of the dash glass
Two teaspoons either side and pry the needle up.
Here's a lesson in pod dismantling
But just FYI if you are doing this to change a motor you don't need to remove all needles and face as I did in the video just the needle in question and work from behind
I read this.
I tried this.
I drove for a few weeks with the front removed from the clocks.
In those few weeks, all worked fine, temp and fuel.
Front back on and the temp gauge is back to its tricks because of the rest stop but the fuel gauge is fine but I dare not put more than ÂŁ40 in it as that's what set it off in the first place.
Not a bad solution if it's the memory but and not the actual motor which has died.
HattieBrooks said:
My fuel gauge has suddenly stopped working, and permanently reads half-full. I've been told that this could be a costly repair - does anyone know any different?
[smiley=gossip.gif]
Hi, If the fuel range shows about the same as the gauge but it is incorrect compared to how much is in the tank, then it's usually the fuel level senders in the tank, otherwise faulty dashpod.
Hmmm, interesting. The fuel pump was replaced a couple of weeks prior to this prblem developing. When I complained to the garage that did the work, it said it would replace the fuel pump again, which it did, though still the gauge does not work. The garage is adamant that this problem is to do with the gauge and not anything to do with thr work it did. Any thoughts on this?
21 - 40 of 42 Posts
