1,321 - 1,340 of 2,841 Posts
Yeah that sounds far too complicated for me.
I was hoping it was just gonna be a simple case of updating the MMI software and enabling smartphone using the long function in ODb11
Me too! You can also have the map license extended as part of the same process (or even have nav enabled if you don’t have it already), you can then install map updates from the VW website (see other threads). There are also options that can be turned on if you have the lane assist camera: High beam assist and speed sign recognition.
How much did you pay for the retrofit, and Whereabouts in the UK are they based.
Yorkshire and South Wales VAG diagnostics on Facebook. He visits other locations too, he was West London at the w/e. Pricing is on his page or message him. No connection other than being a customer, there are others offering similar services.
my car has the firmware version that you see in the picture, can i update it to: MHI2_ER_AU43x_P5098 MU-Software 1339?
if so could someone kindly send it to me?
I always do updates via engineering menu. May or may not work from the normal updates menu, not sure.
Also as shtu says, location of files IS important. Top level (root) folder must contain the metainfo2.txt file (and all the other files and folders at the same level in the zip). If everything is inside another folder (usually the name of the ZIP file) on the SD card the update won't be found.
Hi There,
I've been reading all these posts and I'm so confused as to what I need to upgrade my MMI. My details are
Software version: 0139
Media driver: SOP2_MMX2_AU_ER_G24_044PROD-1
Nav Database Ver V03959801ET 0105 ECE 2015
Please can you tell me what I need and what I have to do to perform the upgrade? Also if I need the cable, what is it and where can I get it.
Many Thanks
Seain
Not an issue I’m familiar with, sorry.
suggest retrying, and if that doesn’t work check your download and contents of the SD card. Perhaps a file is corrupt or unreadable?
Thank you so much @ Kevin#24 and @ Pcbbc. The software update went smoothly. My advice to everyone is to buy a brand new SD card and use that. Don't bugger about formatting old cards and trying to put Fat32 on them. I'm worried about doing the firmware update as I don't have enough experience to be able to decipher all the posts about how the best way to do it is. What exactly are the extras that this gives me and is it worth having a bash at?
So you've completed the "software update". What do you mean by "firmware update"?
To me these are different names for the same thing. Do you mean replacing the stage2mod.ifs?
That would allow you to enable Apple CarPlay, Android Auto, extend your map licences, etc.
SD Cards of 32GB and less should already have FAT32 file system. No need to reformat or buy a new card.
Hi there. Yes, that's what I mean. I would attempt it but I can't seem to find all the info that I need in one doc or post.
[CITAZIONE="kevin#34, post: 9558777, membro: 292141"]
Credo che tutto sia iniziato a causa dell'utilizzo di una chiavetta USB invece di una SD formattata 32:(
[/CITAZIONE] I tried with a 32GB sd formatted in FAT32 the error is identical, how can I tell if the software is not suitable for my machine? by scanning vcds I can understand which vc I mount?
