1,341 - 1,360 of 2,841 Posts
I had asked a question in my own thread about updating, Kevin#34 directed me here, thanks, Pcbbc also kindly replied but maybe it is better if I keep my questions here as this seems the more appropriate thread.
I have 1339 successfully installed but I have not been able to get a Telnet connection working. I cannot locate a Dlink adaptor here in Thailand but I have patched a Ugreen adaptor to look like a Dlink E100, suggested in a German forum this would work but not it seems for me.
Just to be sure I wonder if I missed anything. My car has 2 USB ports, 1 of which has a phone icon next to it. I've tried both anyway but still no beans.
Do I have to have the car setup in any particular way, settings on the VC, left thumb holding the trunk release whilst touching my tongue on the horn push or some other arcane state to enable the Telnet server to start or is it always running?
Just want to be sure I haven't missed anything.
Did you change laptop ip-address?
command prompt as Administrator:
netsh interface ip set address name="Ethernet0" static 172.16.250.123 255.255.255.0
Hi,
Yes, I have the laptop configured with a static address in the same subnet.
I think Amazon or Ebay are likely my only choices. It will take a while to reach here for sure but I guess having the right one is the only way ahead.
HI,
Well a bit of success today. I had been using my son's windows laptop and what I thought was a good ethernet patch cable. Today I thought I would give it one more try, this time I took my old MacBook Pro with and ethernet port on it, a different cable and tried that.
I started the car and entered the red engineering menu, not sure if that is really necessary.
Plugged in and initially arp -a couldn't see anything, ping returned unknown. After a few seconds arp -a returned 172.16.250.248 and I was able to ping it.
Logon went smoothly, see image.
So, a bit of persistence seems to have paid off. This is with a Ugreen adaptor that has the Eeprom re-programmed so the VID/PID is now 0x2001 0x1a02 emulating a Dlink E-100.
Hello everyone .... forgive my english ... thank "google translate". I have read quite a few pages but I am still afraid to update my TT. I have a TT MK3 230hp Stronic Quattro (stage1) from November 2014 Currently has installed: MHI2_ER_AUG24_S0316 MU Software: 0117 Maps 2017 I tried to install the 2021/22 maps but failed. He also sees it from the red menu but it is not possible to start the update. I wanted to know if the file: "TT_MHI2_ER_AU43x_P5098" is correct for my version and if just go to the red menu to start it. My TT is also equipped with "B&O" could this be a problem? After the software update, will it be possible to update the maps as well? Thanks a lot to everyone
once the free map updates have expired, you can't install any new maps, system will not accept them, you need to extend the license validity.
You can install the 1339 version easily (link on previous pages), but be careful to adopt all the necessary precautions (SD no bigger than 32 Gb, Fat-32 formatted, battery under charge etc etc).
If you need more advice, join the Audi TT mk3 Italia group on Telegram
"join the Audi TT mk3 Italia group on Telegram "
just made!!!
But extending the license comes at a cost .... If I update the software, will I be able to update the maps after?
they are 2 separate things: updating the MMI sw is quite easy, but extending the map license not so much (at least for me)… what is good is that for less than half of the cost of just one map update done in Audi, you can extend your maps license until 2030 or later....
I need some help please. I want to update my firmware on my Audi TT 8S MY 2015. Current firmware is MHI2_ER_AU43x_S1070 MU Software: 0380
1. If I understood it right I need tu update to MHI2_ER_AU43x_P5098, right?
Right
1.1. If yes can I update right away from my current version S1070 directly to P5098?
Yes
1.2. If no, witch update train I have to follow when my current firmware is AU43x_S1070?
2. Can I update from a sd-card?
You should do it from SD1
3. How long does an update usually take and can I let engines run just to keep a steady power supply?
Approx. 30-40 mins. You can do it without engine running. To be save you can plug in a chrager. I never update with engine running. I do it with out engine rumning and without charger.
someone have the
MHI2_ER_AU43x_S1070
firmware to downgrade my mib?
regards
You haven’t successfully copied the flashlock executable onto the SD card.
the instructions to do that are earlier in the thread.
Code:
telnet 172.16.250.248 123
mount -uw /net/mmx/fs/sda0
cp /usr/bin/flashlock /net/mmx/fs/sda0/
cp /usr/bin/flashit /net/mmx/fs/sda0/
cp /usr/apps/mib2_ioc_flash /net/mmx/fs/sda0/
Code:
flashlock is a command? I don't see an executable to copy to the sd
Yes it’s a command. I gave you the copy (cp) command to copy it to the SD card.
What do you mean you “don’t see it”?
Have you upgraded to 1339 first?
Perhaps some earlier firmwares do not have it - I really do not know.
It certainly will be present in the default 1339 install, unless you’ve somehow deleted something.
Second what gisuemanuel says. If you cannot follow the fairly simple step by step instructions in the thread that I liked to, you really should steer well clear.
thank you for the help, the command lines have been made with the copy of the FEc backup, I had made a backup then erased the sd to move on to the other steps.
another thing, is it normal that the original fec sds navigation does not appear in the read fec? (it appears in develop mode)
I learn like many people, thank you again
