Though I knew that the lock/unlock chirp could be enabled through VCDS, I didn't realise that it was also possible to enable a menu in the DIS for this (I don't have the chirps enabled, but I like the idea of being able to enable it though the DIS rather than with the laptop).
For cars from 2009 or earlier with the separate central convenience module 46:
- Byte 8, Bit 1 - enable 'Unlocking Confirmation (Horn) via Door Locks'
- Byte 8, Bit 3 - enable 'Unlocking Confirmation (Horn) via Remote Control'
- Byte 8, Bit 7 - disable 'Horn Confirmation Configuration blocked'
- Byte 9, Bit 1 - enable 'Locking Confirmation (Horn) via Door Locks'
- Byte 9, Bit 3 - enable 'Locking Confirmation (Horn) via Remote Control'
- Can now be turned on or off under adaptation channels 7, 8, 10 and 11 or the DIS.
- Byte 5, Bit 1 - enable 'Locking Confirmation via Horn active'
- Byte 5, Bit 2 - disable 'Horn Confirmation Adaptation blocked'
- Byte 5, Bit 4 - enable 'Unlocking Confirmation via Horn active'
- Can now be turned on or off through adaptation channels 10 and 11 or the DIS.
