Lock door with key (door lock LED failure)
2 reading
295 views 5 replies 2 participants last post by  Harm_1
Hi,
As my Audi TT 8S Roadster left (driver) door is replaced, all components are changed from old to new door. Problem I have is door lock LED doesn't light when doors are locked as because of speed or door lock switch. Traced the problem back to door lock unit (=F220) as it gives an implausible status.
One thing I noticed; I can un-lock the door with the (mechanical) key to the left=90° but I can't lock the door with this key) when it's turned to the right=45°.
Questions:
Should it be possible to lock the car with the key (not remote)?
Is it possible the key connection and door lock unit are misaligned 180°?
Hope someone can help.
Thanks,
Harm
module error:
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 E HW: 5Q0 959 593 B
Component: TSG FS 020 0041
Serial number: 141015BJD11317 Dataset Number: 8S0909872D 0020
Coding: 001E43725C08040100001402
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 43D34F116B1626C2529-8016
65593 - Switch for Central Locking B122D 29 [009] - Signal Implausible
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 159
Mileage: 74936 km
Some extra info. Found the problem with the mechanical key. As because of cylinder fixing in the door, mounting screw was too tight and deformed the lock cylinder. Only 45 degrees to the right (lock) and that wasn't enough. With some force I could turn lock 90 degrees in both directions and mechanical locking is OK now.
Still error in module 42, 65593 - Switch for Central Locking B122D 29 [009] - Signal Implausible
With the driver side central locking lock unit out of the car, I measured switch resistance F131:
I've:
door open: 3-5 is 0 Ohm
door closed: 3-5 is 0 Ohm
door closed and locked (V56): 3-5 is 180 Ohm
I can't find position that measures OPEN for F131 switches.
Can somebody confirm my measurements or should I measure different values??
Thanks all!
