Just completed my retro install. Here's a picture:
The double DIN fascia is made by a guy called
Mani in Germany, and is an extremely professional product. It comes completely upholstered (in a very close match to the factory TT interior trim), and as close to a plug a play solution as you can get. The only work required is the actual installation and obviously the small modification of the TT a/c ducting to accommodate the larger unit. It's also available in a variety of different formats to suite different navigation units.
My donor RNS-E is from an A4, a 2010+ PU unit HW03.
I have just about everything working with the unit coded for A4:
* Auto on/off via ignition
* Dash illumination and auto day/night mode with side lights
* Bose (original install was Chorus unit with Bose)
* 6 disk auto changer (again original factory fit install with the Chorus)
* RNS-E clock settings obtained from DIS
* Navigation directions display in DIS (Need to code instrument cluster for navigation)
* After-market 3rd party Bluetooth kit via TEL IN/MUTE on RNS-E
The only thing that is currently escaping me is the speed sensor signal. In the RNS-E diagnostic screens under Nav Sensors, it is showing all zeros for the speed sensor data. I've narrowed this down to one of two things:
1. Either the RNS-E is missing v-signal line on B3. Unless I'm mistaken the Chorus didn't have a v-signal, even though it has GALA. I'm assuming the Chorus got it's speed data over CAN. If this is the case, then I believe I need to wire B3 to the v-signal pin on the back of the instrument cluster?
2. Or the RNS-E is attempting to read the speed data over CAN, which I think requires a CAN Gateway does it not? And the 8N doesn't have a gateway....
Also, the e-bay A3/A4/A6/TT/AllRoad to Chorus/Concert harness I purchased was supplied with RNS-E B3 connected to the old BOSE pin of the Chorus plug III pin 1. And that pin can be v-signal on some head units (without BOSE), can it not? So that makes me think that it's probably option 1 above?
Has anyone attempted this with a RNS-E 2010+ PU unit?
Does anyone know if this unit expects v-signal over CAN or via the dedicated v-signal line? (when coded as A4)
What's the situation with speed sensor data on the pre-2010 units?
Am I perhaps missing some coding?
Adaptation channels 1 and 2 are obvious candidates. But at the moment it appears the unit isn't getting any speed pulses at all...
Any help appreciated - thanks guys and gals.
