Anyone retrofitted wireless charging to their mk2? From the googles I've done the actual installation should be fairly simple but the issue is where is the best place to put it?
I plan to do this soon, and under the rubber mat behind the handbrake seems ideal. Once done it should look OEM. My plan is to run the cable to the 12v power outlet and connect via USB.Se6 said:I seem to recall Retro did this mod and fitted it in the area behind the hand brake so the charging pad was under the rubber mat
