AdamA9 said:
Just checked the oil and it's full... This must be a fault but just got back from Audi and there are no fault codes and they said theres nothing they can do to fix it. The light has gone now, but worried it's going to come back again when I am not near an Audi garage..
Keep an eye on the oil level , once per week if it is your daily car or if you use on only the weekends , you can check it once per month on the same time you check you tyre pressure.
For you not to worry , check the oil temperature when you suspect you are low on oil or when the light comes back on , it if it abnormal and very high then yes you might be low on oil ( I am not a expert but I would say that above 97-100 degrees in normal driving condition will ring the bell for me ).
An other way to check would be oil pressure but we do not have it on our cars :?
My TFSI ( BWA ) has it periods when it " eats " a bit more oil than usual , nothing to worry about , the car " lives ".
Your engine is new , so it is normal. Everything is coming together.
My advice would be to always have 1L of 5W30 in the car so you can fill up should you have to.
( I use Castrol Edge 5W30 and am very happy with it then it is up to your personal preference , but the TFSI technology requires special oil VW 504/507 here is why :
http://www.vwwatercooled.org.au/for...org.au/forums/f112/why-you-need-use-504-507-oils-fsi-tsi-tdi-engines-47140.html )
JBTT
