Rear Mag Ride Shock Absorber Replacement
4.2K views 10 replies 7 participants last post by  SwissJetPilot
Hi guys, my left rear shock absorber has just gone. As I’ve got the magnetic ride option this seems very expensive to replace. I’m not fussed about having the option and was wondering if I could instead fit 2 normal absorbers instead? Any problems that may arise ?
thanks
If you decide to replace your Magride shocks you need to do all 4 since they work together as a set. You'll also need a set of Magride delete adapters to prevent error codes. And if you are going to do it right you will want to replace your springs with a set that is matched to your new shocks.
Additionally, while you have everything apart you'll want to renew all rubber bushings, bumpstops, coil isolators and strut bearings.
Basically it's all or nothing...
Unfortunately it's not possible as the connector is broken internally after the cap is removed.
Now If you did this yourself, there's a debate as to whether or not the cap and connector can be removed without damaging the connector and then reused. But if Audi or any other service center does it, they'll just charge you for a new one.
I suspect there will be other bits and bobs they will also replace, so expect a few additional parts on the final bill.
Good read here on the Mag Ride Cap Removal discussion -
And if interested, you can download the Workshop Manual here.
