Retrofit Electric Seats.. whos done it?
8.3K views 17 replies 7 participants last post by  Nidana
Guys and Gals,
I'm swapping my heated manual adjusted seats for electrically adjusted ones, has anyone done this before?
I just need to find details of the connector I need for the electrial adjustment featre, and how to wire it in.
Just to clarify, all I am adding to my current setup is the electrically adjusted part, I already have the heated part fitted.
Cheers :)
I assume you will require the plug and wiring to give power to the motors at the seat.
If you've gone under and checked what plugs are under the seat and there is no spare one for the motor then more than likely you will need to source it and wire it in.
Just replied to your pm but in general parts need are
Red connector X2
Fuse
Fuse holder
2.5mm² wire
4mm² wire
As always I fitted mine completely OEM but basically they just need power and ground
Power is from the main feed to the cecm
It might be worth adding a reference to the following workshop manuals which are in the KB -
A005TT00420 - General Body Repairs, Interior
Workgroup 72 - Seat Frames Page 273
D3E80079BA4 - Body Interior
Workgroup 72 - Seat Frames Page 248
A005TT20021 - Wiring Diagrams & Component Locations
Wiring Diagram Driver's Seat, Power Seats, Front Passenger's Seat, Power Seats
SwissJetPilot said:
@ MT-V6 and barry_m2 - If you guys are geographically close enough to each other, you should pick a weekend, split a case of beer and do a joint venture on this one!
[smiley=cheers.gif]
Yeah, we aren't too far. MT popped over to mine a few weeks ago to pick a few reverse camera bits up from me that I'm not going to be using, and he wanted to hear what the TTS exhaust sounded like on a V6.
Yes we aren't far, and I don't think we help each other with our spending habits!
I've already finished mine, I actually bought black seats and swapped over the leather covers so took me a while longer. Done now though, aside from the plastic trims that clip over the front of the runners
The reversing camera is my next mod, and the TTS exhaust too at some point!
tttony said:
This German company sells ready made wiring looms for retro-fitting electric seats. They also sell lots of other parts for retro-fitting.
http://www.K-electronics-shop.de
There is an English language option for the site.
Why have I seen this I now have a really long shopping list building up.
It was long enough already but thankyou.
