Just been reading another thread in here, and I must admit I'm confused.
But rather than clog that one up, I thought I'd start a new one
As I understand it, (or rather, as I thought I understood it!), there are a number of factors which effect how quickly (distance wise) a car will stop.
In order to make things fair, I'll assume that some of these are the same (although that isn't the case in real life)
Friction co-ef of the road. Whilst things HAVE improved (Shell Grip), this is not widely used, so we'll assume it's been pretty constant over the years. In fact, we'll run the 'test' on the same bit of road, to take this factor out.
Vehicle weight. Obviously makes a BIG difference, but for this test we'll assume that the comparisons car all weigh exactly the same.
Reaction time. We'll ignore this for this 'test' and measure the distance purely from the point where the driver actually hits the brakes.
Skidding. The point where everything goes pear shaped. Again, we will assume that all the cars on test have identical ABS systems (which is not the case), and that skidding is effectively removed.
Fade. I'm talking about a one off event here, not 25 laps into a race.
Which just leaves (I think!)
The brake system set up - Friction co-ef of pads to dics, size of discs, ventilation etc etc etc
SO. (and I hope you've got this far!)
In the following test, which would stop first (shortest distance) from 70mph?
Completly std 3.2 TT (ie with RS4 setup)
Completly std 1.8 TT
3.2 with 'upgraded' brake setup (say, bigger discs, green stuff)
1.8 with same 'upgraded' setup as above
A 1972 Ford Fiesta (don't forget, same weight, ABS etc etc) - only difference is that it has drum brakes all round*
Please state why when making your choice!
* yes, I have no idea if this was the case, just trying to sort things out, so please assume that was the setup, ok?
