Hi There,
I have this weird problem with my audi TTS 8J. It all started one day when i started the car (after cold snow weather) and my dash language was reset to default (prob. low battery). I had the Tank malfunction error, An error with the ambient temp. sensore giving wrong readings and my fual gauge stuck on empty while im sure the tank was half full.
Scanning the fault codes showed an error on Fuel Sender 2 (it's a Quattro). I also observed that the temp sensore was giving wrong values to the dash and sometime there was no reading at all (just a black part on the HUD). When there is no reading then the dashboard light from suspension would turn on. When the faulty readings got back the suspension light would clear.
Now we are searching to pinpoint the problem. We took the audi repair manuals to check on the fuel sender units. It said the following
- Connect multimeter (resistance test) between contacts -2- and-3-.
With Fuel gauge sender -G- installed:•
Sender at lower stop: approx. 270 Ω.•
Sender at upper stop: approx. 70 Ω.
- Connect multimeter (resistance test) between contacts -1- and-2-.
With fuel gauge sender 2 -G169- installed:•
Resistance would be 270 ohms if tank would be empty (lower position) and resistance would be 70 ohms if tank would be full (high position). We checked on both G1 (fuel sender 1) and G165 (fuel sender 2). Tank was 3 quarter full and G1 gave us 60 Ohms and G165 gave us 200 Ohms... so our guess is that fuel sender 2 is really broken...
But we also checked the voltage on the cable (coming from the dash unit).... both left and right side measure 0.4 voltage on the signal cable from the dash....
Also the ambient temp.sensor shows weird rating like -20Celcius when its +10... those values can change after we turn off the engine and restart it... i have see -8, -20 and also -32... the dash is receiving values but incorrect ones...
So we r trying to figure whats wrong:
1. Temp. sensor broken ?
2. Fuel sender 2 broken ?
3. A dash problem ?
4. Something else ? electrical ?
but i would have expected a fault code then.... maybe u guys can point me in the right directions
3. A dash problem ?
