Tire pressure advice?
2.6K views 4 replies 3 participants last post by  Wormrider
I will soon be putting on the winter wheel/tire setup on my TTRS. The winter setup is 18x8 wheels and 225/45/18 tires. I’m not sure what pressure to use as this tire size in not presented in the owner’s manual (see below). Any suggestions?
Does the sticker inside the door give you pressures for that size setup?
The pressures are virtually the same for every tyre size listed. Only the RS is recommending slightly higher pressures, but are just + 3psi, not a huge difference. Just use the same pressures as for RS with 18" wheels--35 front, 32 rear.
Reactions: Jezzie
