This is the new thread for the 9" Android unit as we were taking over haddek's thread any questions and answers will be in this thread
link ,,, https://fr.aliexpress.com/item/4000466205078.html
Please linkk?? ThanksKnight-tts said:This is the new thread for the 9" Android unit as we were taking over haddek's thread any questions and answers will be in this thread![]()
https://www.aliexpress.com/item/4000466 ... web201603_JoseDC said:Please linkk?? ThanksKnight-tts said:This is the new thread for the 9" Android unit as we were taking over haddek's thread any questions and answers will be in this thread![]()
My unit is the same as the one at the top here in TTSdsgomg’s post. In my opinion it would have been absolutely impossible to fit without the clips breaking. Do you know of any modifications I would have needed to do? My car was fitted with the RNS-E unit with the bose system.Big day for me as I have decided to 'hack' the offending unit to fit
I have a diffent model to 'Knight-tts' and has unusal design which won't fit directly into tt radio cage. I have the silver one the black one might fit without modifying but it had less hardware, I got greedy and will now have to resolve. :?
yikesTaylortony said:Is the fact you no longer have the airbag light on show not an MOT failure?
https://www.gov.uk/government/publicati ... -at-an-motTTsdsgomg said:yikesTaylortony said:Is the fact you no longer have the airbag light on show not an MOT failure?is this true [smiley=book2.gif]
https://www.gov.uk/guidance/mot-inspect ... tion-7-1-52.6 Seatbelts
The vehicle will be inspected to check that:
the mandatory seatbelts are in place
they are suitable for the vehicle
they are in a good condition
they work properly
they are attached securely
The malfunction indicator lamps (MILs) or dashboard warning lights will be checked for the:
air bags
seatbelt pretensioners (which remove the slack from a seatbelt in the event of a collision)
seatbelt load limiters (which release a small amount of belt when it's too tight)
Surely his means of checking it is inoperative is the airbag light, if he can't see it he can't check it, therefore he cannot assume it is servicable, would it not fail? Mind you is it the passenger one?7.1.5. Airbags
This inspection is for all airbags fitted as original equipment other than on Class 3 vehicles.
A passenger airbag that is switched off is not a defect.
Defect Category
(a) An airbag fitted as original equipment obviously missing Major
(b) Not in use
(c) An airbag obviously inoperative Major
thats a possibility, once all other stuff back together will give some thoughtTaylortony said:Maybe into the ashtray if not in use?
looks good, hows your fitting going ?Knight-tts said:Progress![]()
home power up and setting up apps etc
Fitting will be done another day as still tweaking the unit and installing apps and modding the launcher and button that start apps renaming and changing icons making it flow And look better 8)TTsdsgomg said:looks good, hows your fitting going ?Knight-tts said:Progress![]()
Looking nice mate nice progress todayTTsdsgomg said:Okay main unit in place temporarily just to test hacking was successful and it fits. :?
Made temp screen protector from old ipad one whilst fiddling about with fitting.
Easy to tidy with a rubber grommet and more direct route, also I'm keeping all oem stuff in place in case rns-e goes back in. Thats why I hacked the android and not my dashTaylortony said:But surely there is a hole above that for the MMI lead, could you not have used that?
Sure mateTTsdsgomg said:'Knight-tts' hope you don't mind if I continue to post on 'Hadaak' thread, but will update here too.
will this talk to torque app or any onboard data readers ?Knight-tts said:Ok so now got obd eleven pro installed least now there's no stealing the mrs phone so I can go code and fault find whenever I want 8)
