I have a 2011 TDI. Could someone in the know tell me if this engine has a cam belt or chain? I was under the impression it was a chain but I am getting conflicting information online. Thanks
Hi Hoggy, It is comes as a Kit Tensioner and Pulleys Just had mine done....Hoggy said:Hi, Make sure the Hydraulic Tensioner is included in the Audi price, because it isn't in the MK1 & is extra cost.
Hoggy.![]()
Hi, Tensioner is listed in MK1 kit, but it's not the Hyd tensioner. Are you sure it's the Hyd Tensioner in the MK 2 cambelt kit.TDI Roadster said:Hi Hoggy, It is comes as a Kit Tensioner and Pulleys Just had mine done....Hoggy said:Hi, Make sure the Hydraulic Tensioner is included in the Audi price, because it isn't in the MK1 & is extra cost.
Hoggy.![]()
Hi mark,m-a-r-k said:Yes, it's an Audi UK promotion at the moment. I'm having mine done on Monday.
It was suggested to me to get the water pump belt done at same time because it will cost the same amount again to fit that if it breaks (it's mostly labour costs).
You also get free MOT for ever.
ÂŁ499 at Norwich Audi plus ÂŁ50 for brake fluid and free MOTm-a-r-k said:I think it was ÂŁ599.
I had MOT (free), timing belt and water pump, pollen filter and brake fluid all for ÂŁ661.
I can't access receipt at the moment.
The ÂŁ499 includes a new water pump. I don't think there is a separate water pump belt, only the cambelt.m-a-r-k said:I think it was ÂŁ499 for the timing belt but an extra ÂŁ100 if you wanted the water pump belt done at the same time (recommended).
