Hi,
I have just purchased a 02 plate 225 Quattro and took it for MOT yesterday, it failed on a couple of minor things but more concerning it failed on emissions.....as soon as I got home I plugged my laptop in and checked for fault codes and found an EGT fault indicated = 17861 P1453 exhaust gas temperature sensor 1 open/short to B+
I assumed this indicated a fault with the pre-cat lambda sensor so proceeded to fork out my hard earned cash and replace it....only for the same fault to re-appear after I had cleared all codes and started the car! [smiley=bigcry.gif]
The emission test results from the MOT were as follows:-
Fast idle test 1
CO - 7.508%
HC - 168ppm
Lambda - 0.790
Fast idle test 2
CO - 4.805%
HC - 174ppm
Lambda - 0.870
Natural Idle
CO - 4.331%
I really need anybodies help as to what might be the issue here as I am stumped, I was certain that changing the pre-cat lambda would sort it....clearly I was wrong and need to get this sorted this weekend as I need the car to get to work!!
Thanks in advance for any advice suggestions.
Tim
N.B. I must add that I have already searched the forum and while I can see a few references to this fault code I have not found any answers!
Fast idle test 1
CO - 7.508%
HC - 168ppm
Lambda - 0.790
Fast idle test 2
CO - 4.805%
HC - 174ppm
Lambda - 0.870
Natural Idle
CO - 4.331%
Tim
