What does the Audi TT 8J Body Sound Impact Control Module 8J0907159B do?
Saw the modules advertised and wondered what they did.
All the best.
Roy
All the best.
Roy
I don't think that can be the case in the UK because car breakers are removing a lot of them from damaged petrol Mk2TT's and advertising them on eBay and there are a lot of the modules on the UK eBay and the adverts say what car they have come from.For the Mk2TT, the Soundaktor was only available for the TDI. And a TDI Soundaktor can not be retrofitted to petrol engines.
I have retrofitted it in my A3 8V, but I'm not sure if the SAK Gen 2 modules or firmwares from e.g. the 8V and the TT 8S are compatible with the 8J. The 8J SAK module has 10 pins (4 small, 6 large), so it might be somewhat different.This post provides some additional information on this topic.
Translation -
Remove and install control unit for structure-borne sound -J869- and actuator for structure-borne sound -R214
Removal - Remove water tank cover -5- --> Body assembly work, exterior Rep. size 50 bulkhead; remove and install water tank cover.
Control unit for structure-borne sound -J869- Disconnect electrical plug connection -1-. Release latch -arrow A-, remove control unit for structure-borne sound -J869- from holder -arrow B-.
Actuator for prosonic noise -R214- Unscrew nut - arrow-. Remove actuator for structure-borne sound -R214- and disconnect electrical connector -1-. Installation Installation is carried out in reverse order of tightening torque. --> Chapter Assembly overview - Actuator for impact sound and control unit for impact sound
Another picture of thesoundactor and control module -
They have the sound pipe remember. It's the hardware only version that channels sound into the cabin via the intake.3.2 VR6 was not equipped with a soundaktor
